Tranny issues 92 600 F2
Hi,
I posted questions a few weks ago about my 92 CBR 600 F2 tranny problems. It will stall out the motor out if the clutch is let out in or out of gear. It will shift through gears fine.
I took off the oil pan and looked in tranny. The gears in etween the middle shift fork dont move at all and first now wont fully engage.
Does anyone know what the middle third shift fork does? I know power from the clutch basket wont turn ther shaft when i let clutch out.
Could the gears be jamed or stuck?
Nathan Lovern,Va
Nathan Lovern,Va
I was able to look into gears and saw chipped a gear on the gear shaft near the clutch basket. It was a small gear. there is no chain on the bike but i turned clutch basket with large nut on the inner clutch hub. will turn over backwards good but binds in other direction. i say gears is bent also hence the binding.
