Tranny issue
Old Sep 28, 2007 | 07:47 AM
Glocker23's Avatar
Default Tranny issue
2004 F4i
Downshifting sometimes my shifter doesn't want to shift down. Also while in Neutral without moving, it takes some effort to shift down into first. Any ideas what this could be? Does the tranny need new fluid ands it could be something as simple as that? I am not too sure about trannys.
Old Sep 28, 2007 | 08:13 AM
Lrn2Go's Avatar
Default RE: Tranny issue
First off, I can't be much help here, so I appologize for that up front. However, I did want to comment on the "tranny fluid" thing. I'm 99% sure that your bike is a "wet clutch" tranny design. If this is the case, then your oil is working (oil as in Engine oil) as your transmission fluid.
Which leads me to my next question... did you recently do/get an oil change on your bike? If you didn't put the correct oil in it, that can cause some problems...
Old Sep 28, 2007 | 08:17 AM
Glocker23's Avatar
see, like I said, don't know much about the trannys. But I had is serviced at the dealer, at the beginning of the summer, which included an oil change. But if thats the case, maybe I'll have to do another oil change.
Old Sep 28, 2007 | 10:30 AM
troyg3's Avatar
Wow, I thought for a minute that you were going to tell us that your girlfriend had a "surprise" for you. Then I noticed that this was in the general tech forum and was relieved for you.
Old Sep 28, 2007 | 10:35 AM
Glocker23's Avatar
wow...that was random. Ummmm no
Old Sep 28, 2007 | 11:48 AM
Streetdemon's Avatar
I ♥ CBRF
Yeah your oil is the only fluid for tranny and clutch. Check the following for problems:
(1) Clutch adjustment - How's your freeplay? May need to tighten it up a bit
(2) Bent shifter rod or it needs adjustment (had this prob b4)
(3) Wrong oil weight can also cause problems in shifting
I doubt its your tranny. Check your shifterassembly as that was my problem. I pulled the lever off and turned if one notch and grabs the gearsperfect now.
Old Sep 28, 2007 | 12:08 PM
Mr Pink's Avatar
I have an 04 F4i and Ive noticed sometimes slowing down for say a redlight I have trouble downshifting. My fix is to let off the clutch lever, this will re-engage the clutch. Then pull the lever in and try again. It always works the second time around. As for sitting still going from neutral to first Ive never had that prob.
Streetdemon: Ive never thought about adjusting the shifter rod. Sometimes I have problems getting from 1st to 2nd (I end up in neutral). Do you think tightening the rod would help?
Old Sep 28, 2007 | 01:33 PM
I ♥ CBRF
ORIGINAL: Mr Pink
Probably not. My bike had been down so whenI replaced the left assembly Ididn't get the sweet spot on first install. After a few months of ridingI noticed it didn't like taking first gear at all. So adjusted it and problem went away (which may be your prob glocker).
Mrpink - In your case it sounds like you may be taking second at a low rpm...push it a little harder up the dial and you wont touch neutral.
Old Sep 28, 2007 | 01:54 PM
Glocker23's Avatar
to adjust that, are there directions in the manual??? I am at work now and can't look at it
F4iordie
Aug 30, 2013 05:54 PM
Sardo1101
Aug 15, 2011 02:25 PM
itlnF4I
May 31, 2011 02:45 PM
f4orange
Nov 19, 2009 06:12 PM
YellownBlack
Oct 24, 2007 01:52 PM
