Torque settings
Old Jan 31, 2007 | 06:42 PM
all8280bcc's Avatar
Default Torque settings
What is the correct amount of torque on the front and rear tires of an 01 929 my chain keeps loosining itself and i want to know if its the wheel backing off or the chain is about spent.
Old Feb 2, 2007 | 01:36 AM
morehpforme's Avatar
Default RE: Torque settings
The torque setting for the rear axle nut wouldn't matter if the chain is loosening. You should be pushing the axle collars forward with those bolts inside the swingarm. Tighten the nuts down to the swingarm and the collars can't move backwards to relax the chain, regardless if the axle nut was coming loose. Correct me if I'm wrong...[sm=smiley5.gif]
Old Feb 2, 2007 | 01:02 PM
Tahoe SC's Avatar
how old is your chain?
if it's like more than 8-10K miles, change it out. if your axle is loosening...check the chain slack adjusters to see if they are loose as well when the chain is droopy.
Kenneth Foley
Jun 10, 2013 06:43 PM
animalmother
Sep 3, 2009 07:13 AM
thedaywalker
Aug 29, 2008 12:30 AM
06cbr600rrguy
Mar 8, 2007 11:51 PM
cbrforum
May 8, 2006 06:43 PM
