Torque Settings ...
Old May 27, 2013 | 06:49 AM
Kenneth Foley's Avatar
Default Torque Settings ...
Hi All , have just done my first , Carb Clean and Valve adjustment , front break piston and Seals replace , with allot of help here from the form , I also took the radiator off , gave a good scrub and a re-paint , looking good .. Have put all the pipes back on but what I want to know is the Torque setting if there is one for the Jubilee Clips that connect the Pipes to the Radiator etc .... I am not sure how tight these have to be , if a good hand tight is enough or you need to torque them ... Guidance as always is welcome ...
http://www.partzilla.com/parts/searc...TOR/parts.html
Old May 27, 2013 | 10:36 AM
kilgoretrout's Avatar
Administrator - Retired
Hand tight. Just be careful not to strip them.
Old May 27, 2013 | 01:07 PM
TimBucTwo's Avatar
Personally, I'd say, Hand tight. Just be careful not to strip them.
Regardless of what has already been said.
Old May 27, 2013 | 03:09 PM
Thanks
Old May 28, 2013 | 12:29 AM
Shadow's Avatar
Put a little light grease on the worm drive and slots in the jubilee clips - they turn easier and it helps reduce rust.
Old Jun 10, 2013 | 06:43 PM
Sprock's Avatar
Stainless marine hose clamps are good and hand tight plus a 1/4 turn works well for me
animalmother
Sep 3, 2009 07:13 AM
thedaywalker
Aug 29, 2008 12:30 AM
06cbr600rrguy
Mar 8, 2007 11:51 PM
all8280bcc
Feb 2, 2007 01:02 PM
cbrforum
May 8, 2006 06:43 PM
