throttle stop screw
Old Dec 6, 2006 | 08:57 PM
flipsidef2's Avatar
Default throttle stop screw
can anyone tell me were my throttle stop scre screws in, and can it be gotten to without taking the engine out...i found the entire assembly, laying inside my fairing, not connected to anything.....this could be the root of my backfire no start problem.... any help is appreciated
Old Dec 6, 2006 | 09:31 PM
Bobthebiker's Avatar
Default RE: throttle stop screw
I believe it goes in the carburetors, if I'm not mistaken in between the 2nd and 3rd carbs is where it'll screw in. if you're referring to the little cable with a **** on one end, and a screw on the other, thats actually your IDLE adjustment screw, but could cause a no start and backfiring issue.
Old Dec 6, 2006 | 09:41 PM
flipsidef2's Avatar
thanks, very very helpful... i figured if the so called mechanic said it got spark, fuel and air then maybe that screw assembly being out would cause an incorrect adjustment fuel wise or related to casue the backfire and no start... i appreciate the help...
Old Dec 6, 2006 | 10:12 PM
flipsidef2's Avatar
when i put it back in do i go all the way and back out 1 and 1/4 turns (less or more???)
Old Dec 6, 2006 | 10:35 PM
I would go with turning it until the screw just opens the throttle bodies, and see where the bike will start at, then increase the idle just a hair more so that your motor is running at around 1500-2k rpm.
Hurricane9
Mar 23, 2014 04:52 PM
alex913
Jul 10, 2009 04:33 PM
Thomas
Jul 3, 2009 08:35 AM
bsims13
Mar 30, 2009 07:58 PM
98cbr600se
Nov 4, 2008 02:31 AM
