testing a speed sensor
Old Jul 20, 2007 | 12:07 AM
imoujaber's Avatar
Default testing a speed sensor
I have a honda cbr 98 900 CC and I my speedometer and odometer work 2 % of the time only on and off , and when I turn on the bike when it is cold it always works just for the first 5 sec then goes back to zero with no odometer counting , I checked all the wires they seem fine , I was wondering if there is a way to check to see if the speed sensor is working when the speedometer and odometer are not ,just so I can make sure its not the gauges , does the speed sensor emit a signal that can be measured somewhere with a voltmeter ? so I can start eliminating all the possible problems, thank you
Old Jul 21, 2007 | 04:07 AM
chumley's Avatar
Default RE: testing a speed sensor
Hi.
Just gone through the same senario with my cbr 1996.
If you raise the back wheel and spin the wheel you should get fluctuating voltage of between 0-5v on the speedometer.
You will need a manual to find the correct wires on mine the pink wire was the feed to the speedo.
I ended up fitting a Speedohealer,the guys at there technical department where excellent might be woth e-mailing them.
Regards Mark.
support@healtech-electronics.com
Old Jul 22, 2007 | 07:44 AM
TennesseeCBRF2's Avatar
In most Honda speed sensors, the 3-pin connector is al follows: Black = power, green = ground, pink = signal to speedo
Sounds like you have a bad connection somewhere. Maybe do a continuity check?
Conrice
Oct 2, 2014 09:42 AM
Beez Motorsports
Oct 15, 2012 06:33 PM
dscort
Feb 1, 2008 03:33 PM
kukku
Jan 3, 2008 03:53 AM
kukku
Nov 13, 2007 02:48 AM
