testing a speed sensor
I have a honda cbr 98 900 CC and I my speedometer and odometer work 2 % of the time only on and off , and when I turn on the bike when it is cold it always works just for the first 5 sec then goes back to zero with no odometer counting , I checked all the wires they seem fine , I was wondering if there is a way to check to see if the speed sensor is working when the speedometer and odometer are not ,just so I can make sure its not the gauges , does the speed sensor emit a signal that can be measured somewhere with a voltmeter ? so I can start eliminating all the possible problems, thank you
RE: testing a speed sensor
Hi.
Just gone through the same senario with my cbr 1996.
If you raise the back wheel and spin the wheel you should get fluctuating voltage of between 0-5v on the speedometer.
You will need a manual to find the correct wires on mine the pink wire was the feed to the speedo.
I ended up fitting a Speedohealer,the guys at there technical department where excellent might be woth e-mailing them.
Regards Mark.
support@healtech-electronics.com
Regards Mark.
