Temperature problem 600rr 04
Old Jul 16, 2011 | 03:32 AM
kawc's Avatar
Default Temperature problem 600rr 04
First Hii to all forum members, this is my first post on this forum. I hope you will be able to help me. Otherwise i`m from Slovenia and i had already 3 600rr 04.
This is the first time i have a problem with cbr 600 rr 2004. The bike is not showing any temperature its just two blank lines all the time, like there is no temperature. I already changed the sensor on the thermostat, but still the same, i was wondering is there any other sensor that is connected to the motorbike meter(i dont know the right word, the meter, where are mp/h, revs, clock, temperature,...). I`m stuck, and i would really aprecciate any help i can get.
I would be greatfull if you could at least tell me witch temperature sensor is connected to the motorbike meter ?
Thanks in advance
David
Old Jul 16, 2011 | 10:59 AM
segraves1's Avatar
The specific gauge for temperature is call a temperature (temp) gauge and the whole "motorbike meter" is usually called a gauge cluster.
There is only one temp sensor.
On the older carburetor bikes, the temp sensor was a two wire version (signal and ground) and it directly connected to the gauge cluster to feed the temp sensor.
On the newer fuel injected bikes, it changed they added a third three wire (signal, signal, ground) to feed the ECU a temp signal for fueling calculations. There is still the signal wiring feeding directly to the gauge.
Either way, because there is a signal wire connecting directly from the temp sensor to the gauges, if the temp sensor is good, then that would tend to indicate a bad temp gauge.
Chris
Jinvl
F2 Tech
24
Dec 22, 2013 11:01 PM
diegoG
Nov 18, 2010 03:51 PM
jandino63
Mar 6, 2010 01:38 PM
moldousa
May 11, 2008 12:17 PM
CrashParkman
Jan 16, 2008 02:53 AM
