Temp display
Old Oct 28, 2010 | 07:22 PM
There is something to think about when dealing with engine temperature. The fan is not controled by the Thermostat. It's not controlled by the Thermosensor either. It's controlled by a Thermo-Switch. You could unplug your Thermosensor so you don't have a reading on your gauge cluster and the fan would still turn on at the right temperature. If you're having reading problems, then either Thermostat or Thermosensor. If the fan doesn't turn on at the the proper temperature, then your talking Thermo-Switch.
Old Oct 29, 2010 | 04:08 AM
FROSTYBIRD's Avatar
The new thermostat is installed.It now runs at an indicated 75c.We hit it with an IR temp gun and the diplay is reading 7 degrees low.The fan now kicks on at 106 on the gauge.Dirty connection at the switch.Cleaned tightened and greased.All is good.Thanks for the advise
Old Nov 1, 2010 | 06:46 AM
600f4ilover's Avatar
Yay!! )
fireblade929
Dec 1, 2008 05:03 PM
Squee
Nov 4, 2008 04:30 AM
squatmye
Jul 26, 2007 11:52 AM
2k5Silver_Bullet
Jan 25, 2006 11:33 PM
