Tach stops working
Old Feb 10, 2007 | 05:55 PM
98CBR600F3's Avatar
Default Tach stops working
I tried searching for an answer with no luck. I am debating buying a 98 600 F3 and the current owner tells me the only problem it has is that sometimes when it gets hot, the tach dies (although the bike keeps running). What could cause this? I was thinking loose connection, but that wouldn't explain why it only does it when it's hot.
I looked at the wiring diagram and the tach leadgoes straight to the Ignition control module. Does that send the tach signal or does it come from a manual sensor somewhere? Thanks in advance!
Old Feb 10, 2007 | 05:59 PM
98CBR600F3's Avatar
Default RE: Tach stops working
Also just noticed the ignition pulse generator goes straight to the ignition control module. The answer has to be somewhere between the two. Any ideas?
Old Feb 10, 2007 | 06:43 PM
Bobthebiker's Avatar
start tracing the wires, look for shorts in them, poorly done patches, things spliced in and the like.
Old Feb 10, 2007 | 07:14 PM
fishfryer527's Avatar
I don't look at my tach, you can have mine.
Old Feb 11, 2007 | 01:56 AM
98CBR600F3's Avatar
Don't really care too much about the tach....just want to make sure it isnt possible something that will co$t alot to fix..... I will see what I can trace down with the repair manual.....
Old Feb 11, 2007 | 03:09 AM
If memory serves me right, the tach goes to something on the right side, below the CCT. pretty much its likely that sensor in there warms up, and shorts out.
Old Feb 12, 2007 | 12:19 AM
Sproutf3's Avatar
Registered Users
mine does that too, sometimes a good wack will fix it, at most just switch the bike off, and then back on again. That fix's it every time...for a while atleast
CBR forever
Jul 10, 2025 10:32 AM
Austin55cbrf4i
Apr 13, 2012 06:19 PM
Vanimal
Apr 20, 2011 04:18 PM
dylan
Mar 6, 2010 06:47 PM
tashnag87
Nov 3, 2009 08:09 AM
