sync carbs
i sync my carbs last year. no problem..this time around i had to split my carbs to replace a o ring.so i wanted to re sync. now i cant get a steady reading on my gauges. they are all over the place. bike starts fine,choke on choke off works fine. i have check the carb boots for cracks. look o.k. i cant figure out why my gauges are not giving me a steady reading. any ideas?..i did replace the head gasket and all the vavles are in spec.
yes i blance the gages with a other vac pump.
i dont have my gague cluster on the bike i dont think im idle that high but ill check that
i did go back thru the carb but i didnt check the slider vacuum diaphragm. im going to open that and a give it a check
