sync carbs
Old Jan 17, 2014 | 02:41 PM
this guy's Avatar
Default sync carbs
i sync my carbs last year. no problem..this time around i had to split my carbs to replace a o ring.so i wanted to re sync. now i cant get a steady reading on my gauges. they are all over the place. bike starts fine,choke on choke off works fine. i have check the carb boots for cracks. look o.k. i cant figure out why my gauges are not giving me a steady reading. any ideas?..i did replace the head gasket and all the vavles are in spec.
Old Jan 17, 2014 | 03:07 PM
FOGeologist's Avatar
Senior Member and ROTM March 2014
Stupid question: Are you balancing at a high idle, like 2k? I heard that if you try to balance at idle that you'll get bounce.
Old Jan 17, 2014 | 03:24 PM
cookml22's Avatar
Did you rember to blance the gages 1st? Its a commen overlook. On my set you hook all four lines up to one carb make them read the same then your ready to sync. Good luck man
Old Jan 18, 2014 | 08:42 PM
raiden's Avatar
Same problem since I opened the slider vacuum diaphragm .
Old Jan 19, 2014 | 03:10 AM
this guy's Avatar
yes i blance the gages with a other vac pump.
i dont have my gague cluster on the bike i dont think im idle that high but ill check that
Old Jan 19, 2014 | 03:12 AM
this guy's Avatar
i did go back thru the carb but i didnt check the slider vacuum diaphragm. im going to open that and a give it a check
Old Jan 19, 2014 | 01:08 PM
raiden's Avatar
Don't open it cu'z the rubber is shrinked and its hard to align the rubber when u put back the top cover .
lilgeezy
Mar 4, 2010 04:38 PM
CoreyAkaOpie
Jan 31, 2010 04:02 PM
acat04f6
Jan 14, 2010 05:07 PM
srhaugen
Apr 24, 2007 12:47 PM
Laststop
Sep 6, 2005 11:28 PM
