When sync'ing the carbs....
Old Feb 25, 2010 | 08:48 PM
lilgeezy's Avatar
Question When sync'ing the carbs....
How on earth do you see the adjustment screw / adjust the carbs? Here's my setup: I have a 2000 F4. I have the tank propped up as far as I can, still being able to deliver fuel. I left the airbox on, and just put couplers to extend the tubes (originally attached to the airbox) from the carb to a motion pro sync'er. I can stick my head in there and have a really hard time reaching the screws to do the sync. When I think I hit it, I somehow actually rev the engine with the screwdriver, so I pull out.
This was right after changing the rear brake and changing the spark plugs. Compared to those, I thought this was supposed to be easy I am able to attach the motion pro and see just how out of wack my carbs are... and wow, they're pretty bad.
Anyone have advice or pics that might help? I have seen the how-to's for carb sync but it was for a hurricane and I somehow still just can't get it! I was hoping to find a write up on an f4 on the web somewhere but just can't find it!
Old Feb 27, 2010 | 09:23 PM
lilgeezy's Avatar
and, how bad is it to drive it with the carbs this out of sync?
When I turn the screw (and I'm fairly sure that I have the right one) it seems to just adjust the idle. I don't know.
Old Feb 27, 2010 | 10:17 PM
dyracuse's Avatar
need more to go on than that, what is your gauge graduated in?
Old Mar 4, 2010 | 02:38 PM
lilgeezy's Avatar
not sure. It's a motionpro, and says max vacuum is 40 hg/cm. Also - what might I be turning to make the idle increase vs the sync screws? From pictures and the manual I would have sworn I had the right screw.
Old Mar 4, 2010 | 04:38 PM
dyracuse's Avatar
Adjusting the synch may change the idle somewhat since you are changing the opening on the butterfly plates just like when you open the throttle, also, if you're pushing in it may be opening them while you do it, it's fine if the idle goes up a little, you can adjust that later, just get it in sych, readjust the idle, and blip the throttle a few times to check it. If it's done right it should settle out to the same place within 30mm HG or about 1 inch difference on yours since yours simulates mercury
this guy
Jan 19, 2014 01:08 PM
CoreyAkaOpie
Jan 31, 2010 04:02 PM
acat04f6
Jan 14, 2010 05:07 PM
srhaugen
Apr 24, 2007 12:47 PM
Laststop
Sep 6, 2005 11:28 PM
