CANT SYNC CARBS ON MY 95 F3.... PLEASE HELP
Old Sep 6, 2005 | 06:38 PM
Laststop's Avatar
Default CANT SYNC CARBS ON MY 95 F3.... PLEASE HELP
So my bike has been running a little off, sounding a little puttish at idle, drops in power at random points through the power band, and is a lil jumpy. Hooked up my morgan carb tune II and of course, my 1 and 2 were way up there, were as 3 and 4 were almost at the bottom. I adjusted the center screw but accomplished little, either way. I literally went to both extremes very slowly but made hardly any progress. I'm fairly new to the hobby and I have no clue what this could be, any help would be MUCH appreciated.....
Thanks
Jeff
Old Sep 6, 2005 | 11:28 PM
slowpoke's Avatar
Default RE: CANT SYNC CARBS ON MY 95 F3.... PLEASE HELP
I sync my carbs after I clean them. After each piston slide moves freely, after each float is set the same, and after each jet, air bleed, and choke passage is clean. If you are screwing the right screws for a sync and nothing's happening, then the carbs are dirty. Probably the piston slides are sticking.
this guy
Jan 19, 2014 01:08 PM
lilgeezy
Mar 4, 2010 04:38 PM
CoreyAkaOpie
Jan 31, 2010 04:02 PM
acat04f6
Jan 14, 2010 05:07 PM
srhaugen
Apr 24, 2007 12:47 PM
