strange delay on side indicators
Old May 9, 2010 | 05:37 PM
Ncat's Avatar
Default strange delay on side indicators
When I first crank up my CBR 929 from cold, there is a delay of about 30 seconds from when I activate the turn signal switch and the lights starting to flash.
After about 5 minutes engine running the lights flash straight away, as normal.
This is weird. Is there a capacitor in the circuit that needs to get up to charge ?
Or just a dud relay maybe ?
The battery is new, full charge, all other electrics ok.
Old Jun 29, 2011 | 12:31 PM
sharkm87's Avatar
did you find out what caused this? i have similar symptons
Old Jun 30, 2011 | 11:05 PM
justasquid's Avatar
I would check all of your connections within the circuit. Also check to see if it affects anything else. Such as the horn or brake light. But it sounds like a potential lazy flasher relay. It could just be you need to remove it and clean the conections. Put some dielectric grease on all connections.
TKDLANCE
Apr 2, 2013 04:16 PM
stealthCBR929
Dec 12, 2011 01:09 AM
cbrsixpack
Jan 6, 2010 07:14 AM
BRRandon
Jul 15, 2008 10:40 PM
