Starter Valve Synchronization??
Old Oct 21, 2008 | 06:53 PM
trajiks9's Avatar
Default Starter Valve Synchronization??
Has anyone have a Starter Valve Synchronization performed aka (Throttle bodies sync) on your bike? If so what was exactly performed, how often should this be done, who did the work, and what did it cost? And last but least, what results did you notice after the sync?
Old Oct 21, 2008 | 09:30 PM
jonld's Avatar
Default RE: Starter Valve Synchronization??
starter valve sync is the FI equivelant to syncing carbs. You should probably download the service manual for detailed instructions but in essence a syncrometer is hooked up to the cylinders at the vac lines and the you adjust the nuts on the starter valves till all the cylinders are balanced and at proper idle. I did mine 4 weeks back after shimming my valves.
beaty
May 4, 2013 08:14 PM
pablohoney
The Hurricane Saloon
Jul 14, 2010 03:10 PM
pablohoney
Jun 21, 2010 11:29 AM
victory211
Jun 9, 2008 04:32 PM
evandensmore954
Dec 13, 2007 09:03 AM
