Sprocket set up 600f4
Old Dec 18, 2011 | 05:35 PM
Pioneerrider's Avatar
Default Sprocket set up 600f4
Looking to get more torque I am currently running 16-47 wondering if I should go 15-47 or 16-50 thinking 50 on rear will force me to get a new chain because of the size diff.... Any ideas? Also places to get good sprockets thanks
Old Dec 18, 2011 | 06:30 PM
gotcbr's Avatar
Welcome to the forum.
I wouldn't do any more than 15/47.
Many of here on the forum use Sprocket Center. They have good chain/sprocket combo packages & will cut the chain to length for you upon request.
Also, we've had an RK chain rep here recently offering discounts for CBRF members on chain/chain & sprocket combos.
Good luck shopping.
Old Dec 19, 2011 | 08:24 AM
R Dub's Avatar
October 2011 ROTM
+1 to this. This is one of the more popular combos out there. It seems to have good results. If you do much more the bike will be a very high rpm while cruising. Remember if your speedo will be off too so I suggest getting a speedohealer along with your sprockets to fix that.
Old Dec 19, 2011 | 10:41 AM
Thank you yea I was thinking of going 15-47 and should e able to keep my old chain that has only one season on it due to the fact that there is not a huge Jump in size
Old Dec 19, 2011 | 12:19 PM
RobbinsRacing's Avatar
i thought the speedo ran off of the front tire. or is that just on the f4?
Old Dec 19, 2011 | 03:30 PM
R Dub's Avatar
October 2011 ROTM
The speedo does not run off the front tire for any bike. The sensor is in the crankcase and I believe it goes off the transmission output shaft.
Old Dec 19, 2011 | 04:03 PM
zaqwert6's Avatar
Nov 2011 ROTM
Mostly older bikes , pre say late nineties. Most all have changed since then.
Might wanna wait till you need a whole set. Keeping that older chain will likely end up tearing up a new sprocket pretty quick. Especially if you go Alu.
Old Dec 20, 2011 | 08:58 AM
Well once my new tires come in I can pick up a whole new running gear that's no problem front and rear sprocket new chain ... Aluminum or steel ??
Old Dec 20, 2011 | 12:32 PM
gotcbr's Avatar
Steel. Its lasts longer & will be sufficient for everyday street use.
Its always a good idea to change your chain & sprockets at the same time to limit wear & to get optimum performance.
screaminwoody
Sep 18, 2008 10:28 PM
wickeddark
Apr 28, 2008 08:43 PM
squiggy16us
Feb 26, 2007 09:49 PM
