Sprocket set up 600f4
Looking to get more torque I am currently running 16-47 wondering if I should go 15-47 or 16-50 thinking 50 on rear will force me to get a new chain because of the size diff.... Any ideas? Also places to get good sprockets thanks
Welcome to the forum.
I wouldn't do any more than 15/47.
Many of here on the forum use Sprocket Center. They have good chain/sprocket combo packages & will cut the chain to length for you upon request.
Also, we've had an RK chain rep here recently offering discounts for CBRF members on chain/chain & sprocket combos.
Good luck shopping.
Good luck shopping.
+1 to this. This is one of the more popular combos out there. It seems to have good results. If you do much more the bike will be a very high rpm while cruising. Remember if your speedo will be off too so I suggest getting a speedohealer along with your sprockets to fix that.
Mostly older bikes , pre say late nineties. Most all have changed since then.
Might wanna wait till you need a whole set. Keeping that older chain will likely end up tearing up a new sprocket pretty quick. Especially if you go Alu.
