Speedometer work sometime
If the fairings were sprayed and then it started happening then I'd go with loose connection. There are only a few plugs associated with the speed sensor wiring so check them.
Alternatively the Honda speed sensors like the rest of Honda electrics are fragile pieces of crap and fail quite regularly, the F4i for instance is particularly prone to this. The fix is to replace the speed sensor.
Read off the FI code, it will probably say speed sensor or wiring fault but it is worth looking at it anyway.
all_4jah@hotmail.com
04-30-2008 09:22 PM
