speedo/guages question...
Old Mar 13, 2006 | 12:44 PM
Mnemonic's Avatar
Default speedo/guages question...
Hey all,
Im new to the forum, I am building a chopper right now powered by a 2004 CB600F motor.. I am trying to build in a computerized system with a waterproof LCD for the speedometer and tach built into the tank. I really dont know where to start with that, or even if the wiring will be compatible with such a system...
Anyone have any ideas?
Here's some pics of the build so far..
Old Mar 13, 2006 | 12:53 PM
doncollins's Avatar
Retired Administrator
Default RE: speedo/guages question...
What type of exhaust are you planning on running??? Just curios to know how it's going to sound. It'd be funny to hear and see a chopper fly by at 120 screaming like a sport bike.
Are you thinking about using the stock speedo? Cut the plastic off and have it molded into the tank. That would give you all of the indicators you'll ever need. Everything should be easy to trace out with the shop manual... but I'm not sure how the fuel gauge works. I'll assume there's a sensor in the tank of the 04. Can you get that and mount it in the shopper. That's one of the biggest flaws in cruisers, no gauges.
Old Mar 13, 2006 | 01:00 PM
Mnemonic's Avatar
Im going to be running a straight 4 into 1 into 2, the pipes will split right around the bottom of the motor, and come out a little in front of the rear wheel, kinda like an old side exhaust on a corvette... Should give a pretty meaty sound... but either way its gonna sound like a sportbike at 10-12k rpms
I have the stock speedo's... the plastics are a bitch.. I work with metal, not plastic The one thing that is attractive about using the stock guages is i'll have a temp guage on the tach.. But I really am looking for a computer system made for this, if one exists...
Im really trying to break the boundaries on technology with this bike. I already fabricated a stable system for iPod integration with bluetooth wireless headphones built into the helmet, garage door opener, and cellphone hookup. Not the safest things to be integrating on a motorcycle... but it hasnt really been done before to this degree.
-Dan
Old Mar 13, 2006 | 01:06 PM
doncollins's Avatar
wow... [sm=hail.gif]
I just thought the stock speedo would be easiest. The wiring will just plug in and all you'd have to do is get a speedo healer ($100) to fix the reading. Since the tires, wheel base and ... hell everything will be different than the 04, the speedo will have to be adjusted.
I don't know of any other speedos designed to work with this, but I'll look and post if I find anything.
Old Mar 13, 2006 | 01:09 PM
Mnemonic's Avatar
Yea, that was gonna be another post about the healer.. since this motor doesnt have a speedo cable that goes direct to wheel I was wondering how i would have to go about making the reading right... Do you have a link to the speedo healer?
Thanks again,
Dan
Old Mar 13, 2006 | 11:22 PM
05Tribal's Avatar
ORIGINAL: Mnemonic
Thanks again,
Dan
http://www.speedohealer.com/
Always try the obvious first. Good luck on the bike. Keep us up to date on your progress.
Old Mar 14, 2006 | 01:25 AM
cjbettis's Avatar
wow, can't wait see this finished!!!
do you get HondaRider magazine? Jan/Feb 06 had a custom VTX1800 that is SOOOOOOOOOOOO nice
if you have might give you some ideas.....if not let me know and I'll scan in and send
markbarber
Apr 15, 2009 01:20 PM
niner29
Apr 15, 2009 07:44 AM
tmb100
Apr 17, 2008 10:52 AM
causeofim
Sep 3, 2007 08:33 AM
