Question- Will bike start with Guages unpluged??
Hey everyone, Quick Question: Willa 54start or even power up the fuel pump with the Gauges/ instrument cluster unpluged?
Reason im seeking the answer: Im 95% complete with a 929 to 954 upgade and waiting for the 54 gauges to arrive to complete the project. After I did the motor swap and prior to changing the main harness/computer over to the 54's I conected everything to the 29's and the motor ran.... only it would only rev to 7.5k. So now after changing the remainder of the electrical/ including control switches I now turn the key on fully expecting the fuel pump to kick on and ....... Nothing! sould I be looking elsewhere for something?
Thanks in advance,
TMB
Thanks in advance,
TMB
RE: Question- Will bike start with Guages unpluged??
It will start without the gauges plugged in....But u do need to make sure the upper harness that plugs into the gauges is actually plugged into the main harness of the bike. That upperharness controls the fuel pump, headlights, bank angle sensor, and a few more important parts....So without that harness plugged in, NO it will not crank....Sorry maybe i thought to far on the question, LoL....=-)
yes it will fire up and run with no problems. you could drive it without having the front harness connected to the main one. i got my bike like that after the previous owner has crashed and shashed everything. he removed all of the smashed stuff and trew it away. i got the bike like that and drove it for 3000-3500 kilometers before all of my parts came. the only thing is you have to bypass the tip over sensor on the plugs of the main harness. i hear here on the forum that it cannot be done by short circuiting it but my bike was working like that - cannot remember which two plugs were short circuited. the only diff was that when you turn on the key the inj pump starts and does not stop after a while like it does now - it was running costantly from when you switch on the key.
i hope i have been of help and good luck - basicly the cluster or the harness is not your problem it could only be the TOS if you do not have it installed.
Best regards!
Best regards!
ORIGINAL: DarkNess
Best regards!
Best regards!
ORIGINAL: DarkNess
Best regards!
Best regards!
