spark plugs change time?
Old Mar 19, 2006 | 01:26 AM
ejohn's Avatar
Default spark plugs change time?
ok: so when are you suppose to change the spark plugs in 600 cc ? and what symptoms give you the idea they need changed?
Old Mar 19, 2006 | 03:38 PM
thirdgenlxi's Avatar
Ironmang
Default RE: spark plugs change time?
Supposed to change them every 16k miles. A few symptoms of bad plugs may include hard starting, running rough, lack of power and hesitation/stumbling on accel, poor fuel economy, and the exhaust smells strongly of fuel. Unlikely though that you'll have any of these symptoms if changed at the recommended intervals unless you have other problems causing the plugs to foul.
Old Mar 19, 2006 | 10:43 PM
ejohn's Avatar
sounds good. thanks
Old Mar 20, 2006 | 12:40 AM
transamlt1man's Avatar
If you get them symptoms then you have waited to long. Running your plugs to the very end is soo sooooo hard on your coils and such. Running old plugs for such a long time can pull the life from the coils.
Old Mar 20, 2006 | 02:36 AM
Whippet Goode's Avatar
ORIGINAL: transamlt1man
+1; vastly better to change plugs (or other 'consumables' for that matter) sooner, rather than later. The price of plugs are cheap compared the coils, reg/rec, other components.
Cheers
Old Mar 20, 2006 | 12:32 PM
Tahoe SC's Avatar
yo mang...i rarely hearing of plugs going 16K...
Old Mar 20, 2006 | 01:34 PM
ejohn's Avatar
so who makes the best plug for a f4i?
Old Mar 20, 2006 | 02:20 PM
Tahoe SC's Avatar
the best would be the stock iridium but NGK...IMO...
Old Mar 22, 2006 | 12:53 AM
ejohn's Avatar
get this the stock plug and only plug they make for the f4i is 15.00 per plug
Old Mar 22, 2006 | 01:01 AM
dragonmaster_91's Avatar
I run NGK plugs only and I usually change mine every 5k. Platinum.
cbrjohn
Jan 8, 2012 03:01 PM
600rr12
Nov 2, 2008 05:46 PM
pissedoffatmybike
Jun 27, 2008 12:10 PM
shraz
Jan 10, 2007 11:15 PM
