Slapping chain
Old Dec 18, 2005 | 10:36 PM
ghostrider181's Avatar
Default Slapping chain
Hi all,
I have a problem with my 1990 cbr 1000f. When I go to take off the chian starts making a slapping sound then it stops untill I slow down then get back on the power. The chain is not to old or down to the replace mark. there seems to be a rubber wear bar on top of the swing arm could it be this or the cog is worn?. The back cog looks in good order, but I dont know about the front one.
Any advise would be great.
Regards, Steve.
Old Dec 18, 2005 | 10:41 PM
johndoe's Avatar
Default RE: Slapping chain
not sure, may be your chain is a little loose. try tightning it a little. you should have about one inch of play.
Old Dec 19, 2005 | 01:59 AM
slowpoke's Avatar
The chain is hitting something or is very loose. That front sprocket, hidden under the slave cylinder, could have very hooked teeth.
Old Dec 19, 2005 | 01:12 PM
BB 600f4i's Avatar
Check the tension on the chain, but if that's good, chances are something is wrong with one of the sprockets. I had a bike that would start to click or make a slap noise when starting to slow down and starting to speed up. 15-0 Mph and 0-15 Mph. I found a loose bolt on the back sprocket. Tightened it and the problem went away. Didn't run out of alignment long enough to damage the sprocket.
Old Dec 19, 2005 | 02:08 PM
Anubis's Avatar
Check the Chain adjustment like everyone is saying and if that doesn`t improve things take of your rear wheel and check the cush drive rubbers are not worn behind your Sprocket. they lift out and should be a reasonably snug fit.
LowandSlowf3
Jul 16, 2011 04:26 PM
MD_CBR2000_F4
Jul 10, 2010 11:29 AM
cyrusyn
Jul 1, 2010 07:34 PM
BrewCity954
Apr 21, 2008 10:33 PM
ddvs
Jul 19, 2006 07:01 PM
