SICK F4
Old Mar 12, 2005 | 12:35 AM
USMC3531's Avatar
Default SICK F4
2000 F4 starts and idles fine the problem starts going down the road . It runs good up to about 4500 rpm then it starts cutting out almost to the point of dying. At the same time the speedo does not work then at out of the blue the speedo will start to work then the bike will run fine until I shut it off again. Any help would be great.
Old Mar 12, 2005 | 01:42 AM
rEdLyNeR's Avatar
Default RE: SICK F4
Sounds like a choke problem, my be sticking closed slightly until it gets shsaken loose by vibration. Check to make sure your choke cable is pushing your choke back open all the way when you get warmed up.
Old Mar 12, 2005 | 02:41 AM
USMC3531's Avatar
Default RE: SICK F4
Would the choke have anything to do with the speedo not working at the same time?
Old Mar 12, 2005 | 11:20 PM
JAA600's Avatar
Default RE: SICK F4
Sounds electrical to me. I suggest pulling the plastic and start checking wires. Especially the ones going to the speedo. Pull all the connectors apart and check for corrosion. Good luck. these problems are a pain.
Old Mar 13, 2005 | 10:39 AM
USMC3531's Avatar
Default RE: SICK F4
Thanks, I'm going to have to do something. Down here in the south it getting to be riding season and the ol f4 is not ready.
Old Jun 29, 2007 | 02:14 AM
Nukewater's Avatar
Default RE: SICK F4
was this problem ever solved, i have an identical problem right now, please help!
Old Jun 29, 2007 | 05:30 AM
thecannibalchef's Avatar
Default RE: SICK F4
tighten your battery cables!! and check your grounds. does the rest of your electrical work? have you taken the bike apart recently? maybe you thought you got your upper cowl or gauge cluster connectors plugged in but they didnt click, and now they are backing out. maybe a loose ground somewhere on the body?
Alaska
Apr 30, 2009 04:16 AM
drgnfir
Oct 29, 2007 12:08 PM
jaynd
Oct 19, 2007 12:43 AM
CBRCRF
Sep 7, 2007 11:47 AM
hondadriver4life
Aug 6, 2007 12:20 PM
