Shop recommendation in the IE to set up my suspension.
Old Dec 1, 2011 | 04:21 AM
LilRed F3's Avatar
Default Shop recommendation in the IE to set up my suspension.
Hello,
I'm currently looking for a shop in the IE to set up my suspension for my weight(140) and riding style(commuting and running around town). The previous owner was 6' 4" at 210lbs so I'm looking to get the bikes suspension set up tailor made for me.
Thanks,
David
Old Dec 1, 2011 | 09:44 AM
Jim T's Avatar
IMHO, you are the only one that can do that. Everyone likes something different. Take two people same hight same wieght etc. one may like rebound slower one may like compression harder etc. It's all a matter of preference. Trial and error is your best bet. Play with all the settings until it feels good to you and while you're doing that take notes to keep track of the changes, only change one thing at a time and remember that anything you change will affect the others so while putting in more rebound you may want to stiffen or soften the preload. Putting more preload on the rear will shift the bias more to the front etc. Give it a try and do keep those notes.
Old Dec 1, 2011 | 05:00 PM
sparkman's Avatar
Check this:https://cbrforum.com/forum/other-bik...pension-91156/
Hope that helps. Worth a read, anyway.
Old Dec 1, 2011 | 07:08 PM
gotcbr's Avatar
Good advice above on both counts
Refer to the factory Honda shop manual for your bike. It will have the original stock settings the way it came from the factory. Put it back to those specs, try it, & then go from there for your preferences.
ETA: For professional setup assistance in person, try SPORTBIKE SUSPENSION TUNING at www.sportbikesuspensiontuning.net .
Old Dec 2, 2011 | 01:57 AM
LilRed F3's Avatar
Thanks CBRF.
Old Dec 2, 2011 | 04:48 PM
CJardine's Avatar
Track junkie & modaholic
good read with that link think Ill adjust my suspension since the PO was 110 lbs
Old Dec 3, 2011 | 03:00 AM
LilRed F3's Avatar
I'm really looking to set up the sag for my weight and comp and rebound for street/ commuting use.
Old Dec 3, 2011 | 10:45 PM
Jim T's Avatar
In general 3/4 to 1" sag in the front anyway is a good start. Rebound would depend on the kind of surface you are on. The smoother the harder the rougher the softer and rebound would follow the compression setting. What you are aiming for is a solid contact with the surface. The more contact the better. Bouncing is not good. The contact patch should stay in contact with the surface at all times
riclyd
Oct 17, 2012 04:23 AM
deegaw11
North East
Sep 20, 2011 05:52 PM
cruejunkie
Aug 17, 2009 09:29 PM
929_boosted
Oct 28, 2007 01:57 AM
CBRgator
Nov 28, 2005 02:23 PM
