seem to be running on 3 valves
Old Dec 13, 2006 | 01:40 AM
cbr_900rr's Avatar
Default seem to be running on 3 valves
hey could anyone help me i changed all four spark plugs and the bike started right up but now it seems to be running on 3 valve inste4ad of four how it was before i changed the plugs u think i should go back and retrace my step
Old Dec 13, 2006 | 01:42 AM
knightslugger's Avatar
Default RE: seem to be running on 3 valves
I'm sure you mean 3 cylinders... not valves.
refresh your connections. one of the plug boots aren't seated properly.
Old Dec 13, 2006 | 03:54 PM
FATHEADS1KRR's Avatar
Either that or a gap got closed on accident while installing.... or you could have a cracked/bad plug. It happens. Lil short cut would be to dissable the plugs one at a time utill you find the one that doesn't make a diff when you dissable it. That one is your trouble-maker.
Old Dec 14, 2006 | 12:24 AM
crazy900rr's Avatar
easiest way to tell if you're not firing on a cylinder is to let the bike cool, start it up let it run for about a minute, then spray windex on your headder about midway down the front. The cylinder that isn't firing/misfiring will not evaporate the windex upon contact. Once you determine which cylinder is not firing, you can trouble shoot it from there. Good luck.
Old Dec 14, 2006 | 03:19 PM
cbr_900rr's Avatar
thank the 4 plug wassnt in properly now its all good thank for the help
cBrentb
Oct 18, 2012 11:25 PM
camaroloverx4
Sep 17, 2012 06:56 PM
tplatcbr
Jul 7, 2010 11:59 AM
mynewtoy
Feb 15, 2010 02:12 AM
entity-unknown
Mar 20, 2009 11:55 AM
