Seat & rear tail conversion?
Old Jun 6, 2012 | 11:34 PM
BorderLineAlaska's Avatar
Default Seat & rear tail conversion?
In my opinion(and I believe many would agree) the "banana" seat and rear fairing on the f2 is somewhat ugly.
In my case If I am not mistaken the tail is from a F3.. and obviously doesnt fit properly, something you can see if you look closely at the pics. I even had to purchase the F3 tailight when it needed replaced...
Anyways my question is this:
If I wanted to do a conversion to a split seat what would be my best route when it comes to purchasing parts and doing the least modification possible. Im not a stranger to hard work or anything but I would prefer simple quick gratification like anybody else. I have seen people online use a yamaha subframe/seat etc to convert it so I know its in the realm of possibilities and maybe some of you have done this before.
What options are available and logical? And what kind of work/time/parts would I need to achieve this goal?
Just looking for some ideas or advice from people more experienced than myself. Thanks in advance.
Old Jun 7, 2012 | 03:11 AM
That Guy in Maine's Avatar
I would also be interested in this...I've wanted a more modern tail section...but possibly a more modern front too...
Someday...but info would be great if I ever got around to doing this.
Old Jun 7, 2012 | 04:46 PM
Well looking around the net and here on the forums it seems the converstion is quite common. Nostly just pics of people who have done them, not much "how-to" info. I guess we just have to get our hands dirty and dig in if we want one huh lol.
Mainly I would just like to know if I can do it without cutting my frame and welding on another subframe.
Old Jun 7, 2012 | 05:13 PM
gotcbr's Avatar
Chris,
I did the '01-03 F4i split-seat conversion on my F4. The link in my sig-line goes to my tutorial on the conversion.
The F4 & F4i share the same main frame & are basically the same bike...the F4 being carb'd & the F4i being fuel-injected. They both share the banana seat subframe/tail/seat sans the '01-03 split-seat version F4i.
In addition to my tutorial how-to, I've written extensively on doing the conversion to split-seat. Thanks to the split-seat subframe being a direct bolt-up to the mainframe, it makes it pretty easy.
In your case, if you wanted to use a split-seat subframe from a bike like the '01-03 F4i, you'd have to fab up & weld tabs/mount points to your frame. If you have access to equipment & supply, it would be a fairly easy process. I don't recall if it was on this forum, but I have seen an F3 w/ an F4i split-seat tail. It looked great. I've also seen F3's w/ hand fab'd tubular subframes for the track, w/ track plastics.
What you really need to do is decide on which tail you want. Then, consider what's involved w/ making it work. To that, you can make about any tail work w/ the proper tools, equip, supplies, & skill.
Old Jun 7, 2012 | 06:19 PM
armyjeffries's Avatar
You might be able to look up a member named YourEnemy CBR Forum - Enthusiast forums for Honda CBR Owners - View Profile: YourEnemy
He had a f1 or f2, and put a tail from I think an RR, along with the front of an f4i. I don't think he has the bike, but might be able to guide you.
EDIT: Here is the build thread, https://cbrforum.com/forum/cbr-600f2...r-body-133525/ I've looked through it before, but don't remember how detailed it is. That may be helpful. From the pics though, I'm not sure that it is a stock subframe (from anything.)
Old Jun 7, 2012 | 09:06 PM
Originally Posted by gotcbr
Chris,
Really I would be happy with any split seat, anythings better than what I have on it now. Id be more choosy of which would take less modification. Any ideas or thoughts?
Or if it would be all the same amount of work I would probably go with whichever I could find easiest. I see a lot of sub frames online and some of them arent exactly cheap in my opinion. I could get some tubing and make it myself compared to what some of the ebayers are asking lol...
Any incite or suggestions would be appreciated
Ya I was looking at that he did a lot of great work.. maybe Ill shoot him a pm
Old Jun 7, 2012 | 09:19 PM
gotcbr's Avatar
IF you can do your own subframe fab work, the choices are limitless. Its more time-consuming & labor intensive than I think you indicated you wanted to do in your first post.
Otherwise, you're left w/ modding/adapting your tail choices to your current subframe or swapping out the entire subframe & tail.
Tomsy
Oct 21, 2010 09:17 PM
HotNesCBR
Aug 13, 2009 05:58 PM
sharker98
Jan 13, 2008 10:38 PM
jasonp
Apr 22, 2007 07:50 PM
