F2 build-900RR motor swap, 954RR Front end, F4i/RR body
Old Jan 12, 2012 | 12:58 AM
YourEnemy's Avatar
Default F2 build-900RR motor swap, 954RR Front end, F4i/RR body
Ok, starting a fresh build thread, I figured I would post up what I have so far. First off, on several fourms I have read that people have been notching the frame to get this motor to fit, that is not needed and takes a toll on the structural integrity of the frame. Although some mounts do need to be modified.
Started as this:
went to this:
The new motor:
This is what the frame a few other misc. parts will be powdercoated:
And using a 954RR Ti header
The 954RR forks and F3 rear wheel:
Hand polished tree:
And the 954 headers almost bolt up perfectly to the 900:
Old Jan 12, 2012 | 01:51 AM
02F4I1987's Avatar
wow it looks great! talk about a wheelie machine lol!
Old Jan 12, 2012 | 09:52 AM
flyingpig70's Avatar
Thats great!
I have always wondered if a 929 or 954 header would work on a 900 motor. I now have my answer.... Did it bolt right on?
Old Jan 12, 2012 | 10:12 AM
JankCibberf2's Avatar
whats mods did you do to the frame to bolt in the new motor, i currently have my 600 motor sitting in the garage out of the bike looking for a new motor to take its place
Old Jan 12, 2012 | 08:17 PM
adiopunki7's Avatar
i like it
Old Jan 13, 2012 | 01:30 AM
YourEnemy's Avatar
Thanks guys!
The 954RR header is not quite a direct bolt on, cyl 1 and 4 bolt right on, the two in the middle have to have the ears of the flanges shaved down or else they will hit each other.
JankCibber, When I get finished mocking everything up I will take some detail pictures of what I changed, nothing major has been modified on the frame, just the mount that is down by the swingarm, and the welded on spacer on the left side of the frame for the mount above it.
Old Jan 13, 2012 | 12:16 PM
Cool, thats not too bad. It clears the oil pan ok?
Old Jan 15, 2012 | 02:01 PM
YourEnemy's Avatar
Yep, clears the pan fine, I'll try and take a pic or two for you tomorrow.
The only thing I have not checked is fairing clearance.
Old Jan 16, 2012 | 03:34 PM
cgmiller83's Avatar
Is that a 92-95 900rr motor?
Old Jan 16, 2012 | 11:42 PM
YourEnemy's Avatar
Came out of a 94 I believe.
