Sea Foam
Old Mar 14, 2007 | 03:01 AM
xcrusader12's Avatar
Default Sea Foam
Ok guys here is the question.... Some people swear by this stuff... some people hate this stuff... some people put it in their gas...some people put it in thier a$$... haha no... some people put it in their oil before a change(a day or two)... some people put it in thier carbs....SEA FOAM... what is your take???
Also i wanted to use it in my car because she is an old clunker...
I want to use it as not only a fuel stabilizer, but also a (gunk remover) i want to add it to my gasoline... some say not to add it directly to the carbs because it takes all the junk in the carbs and puts it into the cylinders... soo if i slowly burn it in my gas.. will that do anything better...besides cleaning the injectors and crap...
Also i was thinking of adding it to my engine oil for a day or two and then changing it... it sounds a little scary to me but i would probably add it to my gas first and let a full tank run through...
What i want to know is.... what is the difference between gumout, stp, and all the generic stuff compaired to seafoam??? If i can buy a bottle of the other crap for $1 why buy something for $5 that i have to find at some special store.
I know this stuff is not a POWER ADDITIVE it is a cleansing additive and therefore revives the engine to its origional state (or at least "remove" some time)... it makes rpms run higher, idle better, run smoother... and so on... anyways let me know what you guys think and what way is the best to run it into my F3... gas, carbs, vaccum line, oil???? thanks
Take a look at thier website... its pretty good info.... www.seafoamsales.com
Old Mar 14, 2007 | 12:47 PM
mdfirefighter's Avatar
Default RE: Sea Foam
https://cbrforum.com/m_217763/tm.htm
https://cbrforum.com/m_105946/tm.htm
MarkR
Oct 29, 2018 11:34 PM
jam0837
Jun 19, 2009 10:07 AM
jpanside@gmail.com
May 23, 2009 09:54 PM
EwOkIE
Apr 28, 2008 07:28 AM
f3mulatz
Aug 20, 2007 11:16 PM
