scotch tape...
Old Jul 13, 2005 | 02:15 PM
WhiteTailCBR's Avatar
Default scotch tape...
I was wiring new front blinkers and i had to splice two cables together and i didnt have electrical tape so i just wrapped scotch tape aroudn them... is that goign to effect it... its all hidden inside the front fairing so it wont get wet or anything...
anyone?
Old Jul 13, 2005 | 03:34 PM
05Tribal's Avatar
Default RE: scotch tape...
You should go to a place like Radio Shack and get a wire splicing kit and crimp the wires using the proper connectors and plires. If you goto www.painlessiring.com you can find them on their site too. Just wrapping the wires to gether and scotch tape won't do it. In fact the Greggs lights should have come with the connectors so all you need are the proper pliers which you can get at Home Depot really cheap.
Old Jul 13, 2005 | 03:43 PM
NeonspeedRT's Avatar
If you are going to do the job, do it right. Get the right connectors and get electrical tape. Don't half *** it.
Old Jul 13, 2005 | 03:57 PM
RiPTOR's Avatar
Scotch tape will work temporarily. However, given the elements that the bike must withstand... the tape wont last long. If the wires become exposed and get dirty/wet you risk shorting out parts of the electrical system. I highly recommend the correct splicing connectors, and then electrical tape over the connector.
Old Jul 13, 2005 | 04:00 PM
RiPTOR's Avatar
Old Jul 13, 2005 | 05:29 PM
vbh289's Avatar
Do you hear that? sounds like an electical fire....
I had a friend that used scotch tape on his sterio, burned the truck to the ground. FYI![:-]
Old Jul 15, 2005 | 01:47 PM
MapJr's Avatar
Would you put scotch tape on a deep cut you got and keep it on for a long time or put a band-aid on as soon as you could bet one?
Old Jul 16, 2005 | 09:01 AM
mach9's Avatar
Definately get splice or crimp style connectors. With the vibration of the road and the elements, its the most effective and reliable solution. If you use the right connectors electrical tape is a mute point.
WiSH2oo0
Jun 20, 2011 10:16 AM
TC66
Mar 17, 2010 02:31 PM
evankramer
Jul 30, 2009 10:30 PM
cbr600-95
May 6, 2009 08:45 AM
turnerrr600
Jun 7, 2007 04:58 AM
