HELP ME!!!!!
Old Jul 11, 2005 | 04:31 AM
nogohondaf2's Avatar
Default HELP ME!!!!!
I can't figure out what the problem is with my f2. The plugs are firing, but if I spray starting fluid straight down the carb ports it just back fires and nothing else. This bike sat outside in the weather for about a year and never ran again. The carbs have been taken completly apart and soaked, but still nothing please help. I bought it for 700.00 thinking it would be a simple fix. The bike only has 6500 miles on it. It's a 94 cbr f2 600 if that helps.
Old Jul 11, 2005 | 11:51 PM
ooironheadoo's Avatar
Default RE: HELP ME!!!!!
What do you mean by soaked. You must physically make sure every passage is unclogged. My f3 has problems when is sits for as little a 3 mos. Im not familiar with the F2, but if there is a fuel pump you must make sure that is working. Use a Jumper wire to run the pump until the bowls are full. Maybe it sat because there was an underlying problem.
Old Jul 12, 2005 | 04:23 AM
Thank you for the reply back. I soaked the carbs in a carb solution for a couple nights each.As for a fuel pump. I think the f2 is only gravity fed, unless there is a pump hiding somewhere on the bike, but I don't think so. I'm pretty sure f2's don't have pumps but could be wrong.
Old Jul 15, 2005 | 09:12 AM
fasthigh28645's Avatar
Its sounds as though you have a timing issue. The problem may even be in the magneto that reads off your crank as it turns.It doesn't sound as though you have a fuel problem though because it should do more than just back fire. Good luck and hope to see you riding soon.
Old Jul 15, 2005 | 01:47 PM
vbh289's Avatar
it might be a timing problem but....
My 96 F3 did the same thing till I changed the plugs, after that, fired right up and has run ever since. Could your plugs be gas fouled? I would try simple stuff first before you to to more expansive/expensive exploritory surgery on your bike. See if this helps
Old Jul 18, 2005 | 03:02 AM
Thanks for repling back. I just put new plugs in and I keep pulling them out and checking to see if there fouled, but they always look brand new. Right now it's on the back of a Tacoma ready to go to the cycle shop. Thanks for the info! I'll let you know what happens.
