RPMs slow to come back dwon
Old Aug 3, 2013 | 06:59 AM
Mbennett's Avatar
Default RPMs slow to come back dwon
Hello all, I have a 93 600 F2 and I just cleaned the carbs (I removed all the pilot screws and idle air mixture screw the one that is the shape of a D. I did 2 1/2 turns out. As well the needle jet side was cleaned). I put in a new air filter (BMC). My issue is that once revved it takes a few seconds for the RPMs to come back down to idle. Its hard to shift up in gears when the RPMs are so high. Any help or suggestions are well come.
Old Aug 3, 2013 | 07:40 AM
74demon's Avatar
Does your throttle snap back? Check your cable routing. The airbox or something may be pushing on them causing a bind.
Old Aug 3, 2013 | 07:55 AM
Mbennett's Avatar
The throttle does snap back. I had a not so fun time getting the adjustments correct as I replace them as well.
Old Aug 3, 2013 | 01:34 PM
CJardine's Avatar
Track junkie & modaholic
Did you sync your carbs and set the idle after cleaning them?
Old Aug 3, 2013 | 01:39 PM
Mbennett's Avatar
Well . . . I did the best I could for my budget. I did a guitar string type sync when I had them off. Using the string to measure the space between. I did 2 turns out with idle screws. I was wondering should the bike idle if the screw to the left of the bike is all the way out? You know the one that opens or closes all at once.
icedmind
Nov 12, 2013 05:45 PM
tomttt
Feb 21, 2010 07:23 PM
darkyuy
Jun 10, 2009 11:49 PM
cyber00677
Apr 9, 2008 04:51 PM
Kikepiz
Feb 5, 2008 02:22 PM
