RPMs jumpin when at idle???
Old Feb 17, 2007 | 03:44 PM
ironcitykid's Avatar
Default RPMs jumpin when at idle???
I put a new slip on on my bike this past year. It runs fine when but when I'm stoppped at a stop light the RPMs jump up and down. Usually from 1200 to right around 1500-1700 than back down. Someone told me that I might need my carb rejetted if you put on a slip on. It's a 98 CBR 600. What'd you think?
Old Feb 17, 2007 | 09:05 PM
CrF450r420's Avatar
Default RE: RPMs jumpin when at idle???
Sounds kind of like a vac leak. If so you can find it with carb cleaner. The carb cleaner will mix with the air leaking in and cause the motor to rev up.
In Honda cars the fast idle valve can cause this also. I'm not sure if this is also true on the bikes.
Old Feb 18, 2007 | 05:46 AM
shraz's Avatar
mapping might be off now b/c of the slipon
might need carb synch
like CRF said put some carb cleaner
Old Feb 18, 2007 | 05:08 PM
ThisisMickey's Avatar
I had the same thing, I just got a manual cam chain tensioner and it made it much better, it still jumps like 50 rpms but it is a lot better then +/- 250 but it probably is partly carb synch as well
Old Feb 18, 2007 | 09:54 PM
xds949's Avatar
ORIGINAL: CrF450r420
what if i wanted to find a vacuum leak on an FI bike... would FI cleaner work too
Old Feb 19, 2007 | 03:22 PM
CrF450r420's Avatar
Yeah, it will work with any vac leak.
Old Feb 27, 2007 | 04:41 PM
ORIGINAL: ThisisMickey
Is the carb synch a do it yourself type thing or taking it to the shop?
Old Feb 27, 2007 | 05:22 PM
Tahoe SC's Avatar
totally do yourself!
ShindaTravis
Jul 1, 2012 06:48 AM
SPR-GRN
May 7, 2012 06:08 PM
darkyuy
Jun 10, 2009 11:49 PM
Motostunta
Apr 18, 2008 12:02 PM
bgray
Oct 12, 2005 01:34 AM
