rough start, rough idle, rough ride
Old Sep 23, 2013 | 11:51 PM
joefos's Avatar
Is this causing all my problems?
Old Dec 7, 2013 | 12:41 AM
joefos's Avatar
So I've come a long way, the bike went into the shop where they did the following.
New fuel pump, new stator, changed big chunk of wires from behind the cluster and completely rebuild my carbs.
When I picked it up, it idled like a dream. All 4 cylinders firing, purring. But there was not a lot of power.
I've been riding it and some days it runs pretty good, like 80% of how it should, no stalling. However, after riding it for a while, it will become difficult to start after I turn it off sometimes. When it get's cold, it's obvious it drops to 2 cylinders. 1 and 2 are still not firing consistently. I noticed they are both the black with white stripe wires. It's intermittent so I can't test it in pieces. It is worst when the weather is cold. I rode the hills on a warm day and didn't have HUGE power loss, but I couldn't get it above 120 either, 2 days later at night I went up the hill about 30 degrees colder and in 5 mins i was on 2 cylinders, turned around and came home still on 2 cylinders. So my question is...
Where does that black with white stripe wire come from? Is it straight from the stator? I think this is my problem. Any thoughts? I'm not a mechanic, but I've done a lot of basic work. I'd really like to see which wire is feeding these coils/cylinders. Is the cold weather playing into a bad or weak connection?
Thank in advance guys, I think I see light at the end of this tunnel.
Old Dec 7, 2013 | 01:12 AM
joefos's Avatar
ignition control module?
is this it?
Broken wire, bad connection or new one?
Just thinking out loud.
Instagram
http://instagram.com/p/hnIvhTQhao/
Old Dec 11, 2013 | 08:15 AM
sephrin's Avatar
U sure someone didnt drop a hyundai engine in it?
Old Dec 11, 2013 | 07:49 PM
joefos's Avatar
Well, not sure how that was intended, but it's the original engine. The one wire that feeds the coil for plug 1 is the same wire that feeds the other coil for plug #2. I'm going to have a buddy test it leaving the ECM and compare. It to the plug 3 & 4 coil sides. All I can do is compare I guess.
I may just solder another wire on and run it to the cables and ride it for a couple days. That should narrow it down to ECM or wiring issue. Hope this doesn't mess me up. Let me know if you see somthing I don't. Hope I don't fudge anything up in the process.
Old Dec 12, 2013 | 08:19 AM
sephrin's Avatar
It was a joke, my daughter's grandma drives a hyundai and sometimes its slow and randomly it will want to act like its a ufc fighter on a rampage. Burning out an such. They are somewhat irratic engines from my experiance. Sorry man its a honda, it will run good once the issues are addressed
12stones
May 20, 2019 03:37 PM
Vhandyside
May 23, 2012 03:13 PM
Tort93f2
Apr 13, 2012 12:18 PM
crazie929
Apr 6, 2012 04:30 PM
f3BikeR
Jan 11, 2009 01:35 PM
