Ride height front lower - turn easier?
I spoke to a lady who worked at cycle gear, and I mentioned to her than when I try to turn really sharp and slow (such as a u-turn) the handlebars tend to go into the tank of my bike (I have a 2007 1000rr). She said if i lowered the front slightly, it would actually make turning easier since the handlebars would be higher up on the tank. Now I don't know if that's true, if any other riders has more knowledge that would be great.
That's just one benefit other than drag racing that I could think of
My son has been racing moto x for 10 years and whilst prepping the bike for tight tracks we always drop the front end. Only by mm but it pays off. You can turn faster.That would be the only reason to move the rake angle. A more nimble front end. Not sure thats the solution for you though. Maybe ? The downside to this proceedure is high speed stability. Are you sure your handlebars go into your tank ? Is it possible you are just on full lock ? If your having "u turn" probz with your bike I would get in a few slow, tight, figure of 8`s in a car park somewhere. Bet your issue soon disappears. Best of luck fella
Not sure one your bike but typically sliding the fork tubes doesn't move the handlebars.
When you raise or lower any part of the bike you are changing the weight bias and changing the effective rake and trail of the steering geometry. It also slightly changes the swing arm angle relative to the ground. This is a more sublte issue in regards to 'handling'.
When you lower the front end you decrease trail which lowers the ratio between steering input and direction change. ie....steering becomes 'faster'.
I know if it is off x-amount of millimeters can cause what you were explaining..
so if anything i would probably raise the front up to where it belongs or lower the back seeing the last owner didnt do it right.. suspension is an art on these bike all to themselves..
theres plenty out there out there on fine tuning suspensions, especially on utube.. type in on the "throttle with dave moss" on utube.. you'll find a wealth of information there...
keep us posted on what you do..
jay
