Replacing the headgasket
Old Feb 16, 2012 | 09:42 AM
JankCibberf2's Avatar
Default Replacing the headgasket
I just tore apart my motor replacing the transmission in a bit but before i tear apart my second motor (mind you both have fine headgaskets) should i replace the head gasket with a new one, or can i safely reuse my old one
Old Feb 16, 2012 | 09:54 AM
74demon's Avatar
never re-use a head gasket. they seal by compressing them between the head and block. they are one time use gaskets.
Old Feb 16, 2012 | 12:30 PM
sounds good just ordered another one for 80 bucks... Also any tips for pulling the clutch basket while the motor is off the bike
Old Feb 16, 2012 | 07:34 PM
MadHattr059's Avatar
Too much wrenching involved if it fails, replace the head-gasket don't re-use.
They crush when you torque it all down. Only works properly once. Save the tears.
As far as clutch basket, they make a tool that holds the basket still, or try an air-impact.
Ern
Old Feb 16, 2012 | 09:26 PM
made a ghetto fab tool, and got the nut off. found out my old motor didn't have a bent rod but instead it had a spun bearing
WBBulldogs
Nov 25, 2009 06:23 PM
THC-cbrF2
Apr 2, 2009 11:43 PM
Imo000
Jan 2, 2009 09:25 AM
two240s
Oct 18, 2007 06:30 PM
nrok2118
Mar 21, 2007 02:34 AM
