fixed headgasket....now timings off.....cylinder not firing?
[hr] so I just finished changing the headgasket on my buddys f2. taking it apart and putting back together went real smooth. got the timing marks lined up perfect. it starts and runs but sounds as if the timing is off. it also sounds like the timing chain has some slop in it. we took the cam cover off and double checked the timing. it's perfect. the #4 cylinder also doesn't seem to be firing. the #1-#3 cylinder exhaust pipes are hot. the #4 is not. it's getting spark.
I'm at a complete loss here and it's really starting to **** me off. anyone got any ideas.[/align]
RE: fixed headgasket....now timings off.....cylinder not firing?
it's got spark, got fuel, got compression. how could I have a bent a valve? we set the cams in just as the book states and the timing lined up perfect. after we started it up it sounded like a timing problem. Immediatly took the cam cover off and checked the timing....it's still right on the money. The way it's acting it seems like the only thing that could be wrong is a stuck or bent valve.
If the engine was rotated too much without the cam chain hooked up, you could have rotated the engine to the point where a piston hit an open valve. Enough force could have bent the valve. Very common on DOHC or OHC engines. You say that you have compression, but how much in each cylinder? Do a compression test with a gauge, and see how much compression you have. If your valve is bent, you won't have any compression on that cylinder. I agree with the above post too, check your fuel. The carbs are vacuum operated, so you'll need a vacuum gun (MityVac) to apply vacuum to the carbs with the bike not running. Then you can turn the throttle to see if fuel is coming out of the carb. You can rent these tools at Autozone.
