rear suspension
Old Mar 14, 2007 | 05:43 PM
tombooze's Avatar
Default rear suspension
yo im thinking of adjusting the rear shock as it seems a bit low.... im 6 2" an about 110kgs.can anyone advise me on thecorrect set up,pros cons etc?????cheers TBZ
Old Mar 14, 2007 | 06:19 PM
Jaybird180's Avatar
Default RE: rear suspension
If you're talking about a stock rear, you first of all are going to need a new spring. Some shocks are rebuildable from the factory some aren't. Nevertheless, with thenew spring it will sag in the range you need, but it's ride characteristics are pre-defined by the rebound/ compression adjustments available from the manufacturer.
Old Mar 14, 2007 | 08:08 PM
Tahoe SC's Avatar
you really can't raise the rear much. you can add shims or washers but it'll only get you a few mm's....other option would be to swap to an aftermarket adjustable shock...but it'll cost you.
KidCr3nshaw
Oct 19, 2006 11:37 AM
e3gordon
Sep 25, 2006 03:25 PM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
