Rear brake pedal return spring... size = ?
Old 05-15-2008, 11:53 AM
SpecR's Avatar
Default Rear brake pedal return spring... size = ?
Does anyone know how long the rear brake pedal's return spring is (unstretched)? I lost mine and I think I might be able to replace it with one from a hardware store (DoIt Centers carry door springs that look similar)...
Ideally I'd like to know how thick the coils are too, if someone has a caliper.
Old 05-15-2008, 12:17 PM
Nauree's Avatar
Default RE: Rear brake pedal return spring... size = ?
Just buy a spring you think is long enough and wide enough and cut it to length with some clippers. Just make sure its strong enough to be able to return the pedal yet not too strong to where your forcing it down.
Old 05-15-2008, 02:14 PM
SpecR's Avatar
You can't cut down a return spring... it has hooks on each size.
I meant to post this in the F2 section.
highercal
F4i - Wanted
07-05-2012 05:32 PM
xvcydvx
03-23-2009 08:17 AM
spdbump36
02-18-2008 11:49 PM
morpheous283
05-04-2006 09:27 PM
Quick Reply: Rear brake pedal return spring... size = ?
