Race Specs
Old Mar 22, 2006 | 12:58 AM
FutureFXChamp's Avatar
Default Race Specs
I am Riding a CBR 1000rr on the streets, been on two wheels for years now. Finally have the funds to start racing, got the competition license and an '05 CBR 600rr race bike. What parts, adjustments, etc.... do I need/want to have? Anything from tires (i'm running Pirelli Super Corsas) to fork adjustments, rear suspension adjustments, chain/sprokets (i've got 15/42 w/ 520 chain) and engine parts and exhaust. I found the best way to learn is to ask more experienced riders/racers. thanks for the help.
Old Mar 22, 2006 | 12:20 PM
Tahoe SC's Avatar
Default RE: Race Specs
yo mang...you may want to check the racer sites...
i would get the suspension dialed in just for your weight, assuming it's not the stocker on there....as far as chain, DID 520 fo sho but sprockets, will range from track to track...some have long straights and very slow turns, etc...or long sweepers, etc. so will require different gearing.
tires are good...as far as exhaust, do a f/s...dyno tuned...and if you gots moneys...engine internals, cams, heads, etc...
this is assuming that you gots the bling...
Old Mar 22, 2006 | 12:21 PM
13brsxsrr's Avatar
ORIGINAL: FutureFXChamp
Your best friend is going to be a 1/8 drill bit, and saftey wire plyers. I forget which bolts you need but Caliper, axels, and oil drain are a mandatory. Everything else is how serious you are and how much you got to spend? I'd start w/ sliders. If the Corsas are brand or new enough get a session or two out of those then I would roll w/ the Michelin Pilot Race. Find out your body weight to suspension ratio to adjust ( I asked the same question) and gearing -1 front/ +2 rear. Everthing else is really how serious are you? Maybe tire warmers, stands, extra set of wheels w/ tires, race body work, ohlins dampner. As far as engine and exhaust who needs horse power when you can ride! LOL
Good liuck homey be safe
awjohnston
Mar 9, 2009 02:21 PM
nasty
Nov 28, 2006 01:20 PM
latin
May 17, 2005 10:09 PM
