R4i wont go into 3rd gear
Old Aug 19, 2007 | 11:02 PM
causeofim's Avatar
Default R4i wont go into 3rd gear
I have a 2002 CBR600R4i that has a third gear problem. All other gears work fine but will not go into 3rd gear at all. I was tolf that the shift forks may be bent.
I want to try and fix it myself.
What parts should I buy and where should I start?
Thanks for the help.
Old Aug 20, 2007 | 11:00 AM
dorkbiker's Avatar
Default RE: R4i wont go into 3rd gear
Warm the bike up, then drain the gear box over a magnet. (Stick a magnet in the oil stream as it empties) Hopefully, you won't seeany metal on the magnet when you're done. If you do, start searching ebay for a transmission...it's easier and often cheaper than a total rebuild.
If no, down load the manual and read up on the shift fork assembly. The shift fork isn't too difficult a job. You could check the shift fork first, but it's easier to check for problems internally by the magnet test. The fork won't matter if it's internal problems.
Hell, there may be a magnet on your drain plug. Hadn't had to change my oil yet, my bike is still relatively new to me.
Old Aug 20, 2007 | 12:25 PM
causeofim's Avatar
Great! I'll try that and see what Ifind.
Old Sep 8, 2007 | 05:08 PM
causeofim's Avatar
No metal in the oil, so I assuming it is my shift forks.
My Sunday project.
Old Sep 10, 2007 | 09:32 PM
causeofim's Avatar
I pulled out the shift drum and forks. They seem pretty good.
The left side fork is a little worn, very little.
The drum has a 1mm size piece chipped off of it.
Would this be the problem or do I need to replace the whole works?
Old Sep 10, 2007 | 09:35 PM
causeofim's Avatar
ORIGINAL: dorkbiker
It is actually quite a job on the F4i. You basically remove everything from the lower part of the motor.[&:]
Old Sep 13, 2007 | 07:46 PM
causeofim's Avatar
Any ideas?
Old Oct 4, 2007 | 07:09 PM
causeofim's Avatar
I ordered new shift drum and forks. I replaced them and scrubbed my clutch plates. Put everything back together. It goes into 3rd gear now but under hard acceleration it pops out of third and back into 2nd.
What's going on?[/align]
fdrifting
May 29, 2011 03:44 PM
RoosterF3
Feb 3, 2011 07:02 PM
badpie426
Oct 24, 2010 09:08 PM
badpie426
Oct 24, 2010 10:56 AM
P954
May 30, 2007 12:41 AM
