wont go into 6th gear????
Old Oct 23, 2010 | 03:02 PM
badpie426's Avatar
Default wont go into 6th gear????
Hey I just bought a cbr 600 1996.....all seems fine except I was riding at about 45 an it wouldn't go into 6th gear....all other gears are fine though any ideas
Old Oct 23, 2010 | 03:23 PM
PlayfulGod's Avatar
sure you counted right? Not to mention 45 in 6th would feel awful sluggish.
Old Oct 23, 2010 | 07:47 PM
justasquid's Avatar
without knowing your experience... I would suggest making sure you are starting out in first gear and not second. First gear is all the way down... then up one is neutral, up two is second gear and so on. If your going from neutral and then into second gear to take off, you may be in 6th gear and not even know it.
Old Oct 24, 2010 | 08:47 PM
CBRfenatic93's Avatar
If you go down once and up five times your in 6th gear.
Old Oct 24, 2010 | 09:08 PM
Michael S's Avatar
I've got the same issue with basically the same bike. Spoke with people at a local shop and they said that it's probably a bent shift fork. Probably not worth fixing because it would cost more to fix than the bike.
Believe me, I've run it down the road just to count the number of gears a few times. It's definitely only going to 5th gear.
fdrifting
May 29, 2011 03:44 PM
RoosterF3
Feb 3, 2011 07:02 PM
badpie426
Oct 24, 2010 10:56 AM
causeofim
Oct 4, 2007 07:09 PM
P954
May 30, 2007 12:41 AM
