question about installing aftermarket turn signals
hello,
I recenly bought a pair of led front turn signals and I do not know how to install them. Can anyone help. I have an 07 cbr 600rr. Do I need to take the fairing off to reach the turn signal connector or is there an easier alternative ? I have also heard that the turn signals flash at a rapid rate when installed, what must be done to fix this?
Here is the picture of the turn signal.
RE: question about installing aftermarket turn signals
i have the same pair of signals instaled on my '03 600rr,
i took my fairing part way off to reach the conector, you might beable to get to it with out doing that, but i would just undo a few bolts,
if you have LEDs and resistors in the rear then you wont need them in the front.
if you do need resistors then you need to use them to bridge between the hot wire and the ground.
Lowridese
05-01-2010 01:12 AM
tkahne88
04-09-2010 12:55 AM
ciupe
03-17-2006 10:53 AM
