Problems with tube breather
Hello all!
I have a question regarding my fuel tank.
Because of a earlier problem I have detached may fuel tank. But when I wanted to replace it back I saw there was coming fuel out of kabel 16 like you can see on the pic. This is the tube breather.
Where do I have to place this tube back on the motor, and why is fuel flowing out through this cable when I am holding the fuel tank in my hands when placing it on the motor??
Your help will be appreciated!
Thanks in advance...
There should be 4 hoses total. 2 coming off the petcock (larger one is fuel outlet and the smaller one is vacuum hose that goes to the number one carb on the left side of the bike). 2 coming off the tank towards the rear. The larger one is a breather hose and the smaller one (which is the one in question) is a drain hose. It does not go anywhere except for a small bracket around the idle control where the drain and breather hose clip into. I'm not sure why gas is coming out of it unless you have a lot in the tank and it is just sloshing around when you put it back on. Is it leaking with the tank sitting on the ground?
busyychild
Aug 3, 2007 07:13 PM
