power commander?
changes air/fuel ratio. there is a program where u can lean or richen the mixture at different aspects of rpm and throttle position.
Is it worth it? Some say yes...some say no.
Most people will say that you should get it tuned professionally which will cost a decent amount of money.
Do you absolutely need a power commander for a slip on? ..nope
you will prob notice that eh powerband will smoothen out.
I just bought one...but imo I wouldn't pay 270 or whatever the msrp price. Check ebay...people let used one go for cheap. .I picked up mine for 150 which made it worth shoving out the cash for. def check craiglist too...some girl was sellin hers 100 obo...i was about 10 minutes too late
Im not sure if the presets are stored or not once the battery power is removed from the power commander, but either way, your going to want to map it for your bike and your bikes exhaust. You can download preset maps that are a generic map for your bike and exhaust. But, they are just that, a map that will cover a wide range. Your bike will fall somewhere in that range, but it will probably not make your bike perform the best. As chetman said, most people will suggest getting it tuned once you get the power commander.
IMHO, if your not going to get it tuned, its probably not worth the money to buy one for just a slip on. Of course, if you are noticing any stumbles or hesitation with your current set up, then a power commander can take care of those issues and clean up your response throughout the rpm range.
Basically everything chetman already said...
If you're going to get a PC and use default maps, then don't bother. The whole point of a PC is to have something precisely programmed for YOUR bike, and the way YOU ride it. Uploading a map that someone else claims is aawesome may make your bike run like ****, because you don't ride the same way he does. This also means don't get it done at those places that don't let YOU ride the dyno. A lot of "track days" places will have a group come down with a dyno, and they'll do free custom PC maps for you if you pay for the dyno, or other deals. Look into that.
If you get a PC, you get your bike dyno'd, and you use a custom map for it. That's just how it goes. Just throwing one on for the hell of it is a supremely inefficient waste of $200+. You can get better performance from other $200 parts, than a stock PC.
Finally, don't even hit the dyno until you've already done all the other performance mods you plan on doing, for obvious reasons.
maxwell139
05-16-2006 01:30 AM
