Power Commander 3
Old Sep 10, 2013 | 11:37 PM
KSAUDIO's Avatar
Default Power Commander 3
I have a 1995 Honda CBR 900rr. I would like to know if a Power commander will work with it. What other upgrades can I do to the bike? thanks
Old Sep 11, 2013 | 03:25 AM
Bryce Swartzwelder's Avatar
Default No
Power commander works with fuel injected vehicles and is not compatible with your machine.
Different air filter, HA-9092-A - K&N Replacement Filters, Replacement Air Filter direct from K&N exhaust and proper jet / dyno tune recommended to enrich the fueling for the set up you install. Some exhaust systems are sold with in conjunction with jet kits. Without a dyno and proper air fuel metering equipment, you risk damage to your engine from improper set up.
Or you could dump a load of money into it and build it up. But for that amount of money it pays to buy a bigger newer bike. There are plenty of others who own bikes just like yours and have the tricks to make it walk the walk. Look around a bit.
Old Sep 11, 2013 | 04:43 AM
CJardine's Avatar
Track junkie & modaholic
If you're going to go with a reusable air filter I would recommend BMC over K&N, I know on my F4 I get better throttle response and it feels overall better with the OEM (over K&N!) and with a good rejet the BMC will perform nicely. Furthermore, there is a risk of damaging your engine internals if you use an oiled filter and you don't maintain it properly. With a slip-on and a K&N/BMC you can get away with not rejetting. If you manage to find a full system and a BMC "high flow" Race air filter you will definitely need to rejet If you want to see what happens when a bike hasn't been rejetted with a full system and a "high flow" air filter I can make a video for you as I have mine sitting in pieces in the garage and I can put my second set of carbs on.
Edit: http://www.bmcairfilters.com/search_...marca=50&lng=5
Old Sep 12, 2013 | 05:35 PM
KSAUDIO's Avatar
sweet thanks. I have upgraded the spark plugs and the air filter to the K&n Filter. I am looking at upgrading the windshield to the racing one. I upgrade the lights to LED also I am doing a little bit by little cause I am having a hard time finding things for this bike. thanks for all your help.
Old Sep 12, 2013 | 09:58 PM
CJardine's Avatar
If you let us know what you need we can help you find it.
Old Sep 13, 2013 | 11:12 AM
KSAUDIO's Avatar
I need the clip on hands and the right side foot peg with brake lever on the peddle. A front head light. I would like to change out the high and low lights to a brighter light. I also need a exhaust pipe that is bolts on. thanks for all your help.
Old Sep 14, 2013 | 03:12 AM
Nokya makes quality bulbs at reasonable prices available in different colors arctic white seems brightest 7000k. If you buy stage2 bulbs you might want to ask around first (the higher wattage may melt the housing or tax the charging system). Amazon sells a two pack for under 20 dollars shipped. They seem to last.
Karmakazi
Sep 29, 2009 09:58 AM
joe-4422
Apr 7, 2009 09:47 AM
five0addict
Sep 21, 2006 06:17 PM
dudek12
Aug 9, 2006 01:13 AM
maxwell139
May 16, 2006 01:30 AM
