Power Commander
RE: Power Commander
You will be close enough. Stock maps are fine until you can get to the dyno.
Where you will get into problems is using someone elses map that was dyno tuned. Stock maps tend to be rich for your motor's sake. A custom map could be right on the edge where the most power is made. If your bike was running leaner than the bike the map was made on, you could have some detonation and that's REAL bad.
maxwell139
05-16-2006 01:30 AM
