Oil Question
Old Oct 2, 2006 | 04:25 PM
stuntn_r6's Avatar
Default Oil Question
Is there a difference between Honda 10W-40 oil and every other type of 10W-40 oil out there?
Old Oct 2, 2006 | 05:38 PM
Tahoe SC's Avatar
Default RE: Oil Question
there are lots of differences between oil...additives, etc...
do you have a more specific question?
t
Old Oct 2, 2006 | 05:50 PM
stuntn_r6's Avatar
just wondering if there is a difference bewteen motorcycle oil and car oil....
Old Oct 2, 2006 | 06:05 PM
knightslugger's Avatar
depends on the specific oil. most automotive oils are energy conserving, which isn't great for the clutch. With that said, SG grade oils aren't too much different than most motorcycle oils, but there is so much spectrum when discussing oil that one paragraph about it isn't nearly the whole picture. why are you asking anyway? are you going to change your oil soon? are you asking so you don't use the wrong kind of oil? you're safe if you stick to motorcycle oils, but use discression when seeking out automotive grade oils. it will say weather or not it is Energy Conserving right on the API label found on the back of the oil container. JASO certified oils are good as well. just remember not to use any other viscosity oil than what the manufacture recomends. if it says 10w40, use 10w40, if it says 15w50, use 15w50.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
