oil pressure problem vid
Old Jan 2, 2008 | 08:16 PM
demonchild's Avatar
Default oil pressure problem vid
I posted this in the 954 section, however, this is definitely not 954 specific. Therefore, if anyone can help out go ahead and tossin you thoughts.
linky: https://cbrforum.com/m_456339/tm.htm
Old Jan 3, 2008 | 01:32 AM
marc0011's Avatar
Default RE: oil pressure problem vid
Besides an oil pump going bad, I would also look at a couple other things. The F3 has an oil pressure relief valve justforward ofthe oil pick up. My guess is that there is one on your bike as well and it might be have gone bad. On the oil pick up, there is a strainer and it could be plugged, easy visual check while you have the oil pan off. What about the oil level and what type of oil did you use (not questioning skills, just covering possible causes)? There could be an internal oil leak but my guess is you would of seen it when you changed the oil. Just in case, check your coolant. Make sure it's not a brown color at all. If all this checks out, follow up on bobjoezx suggestion also. Could just a be a bad sensor. If you do determine that it is a bad oil pump, bo here to buy it, it should becheaper. I didn't see a 954 listed but just give'em a call for the pump price.
http://www.ronayers.com/index.cfm
kwood
Jun 1, 2020 09:53 AM
G3NESYS
Mar 26, 2011 09:39 AM
demonchild
Jan 21, 2008 10:07 PM
jetchee
Oct 18, 2007 10:33 AM
kamranh1
Dec 25, 2005 09:21 PM
