oil capacity
Old Jun 20, 2011 | 10:11 PM
Poblete's Avatar
Default oil capacity
i have a 2006 honda cbr600rr. im going to try and change the oil without removing the ferrings. but i dont know how much oil she takes people say 3.25 quarts some dealers say 3 and some say 2.7. its pretty hard to even see the line on the eye glass. but i know im going to get a oem filter and 10w40 amsoil motorcycle. but how many quarts does she hold?
Old Jun 20, 2011 | 10:40 PM
justasquid's Avatar
Are you just changing the oil and not the filter? I didn't think you could change the filter without removing the fairing. Even if its possible, its not hard to drop the lower section fairings. Plus, you won't have to worry about getting oil all over them and you will have a lot of room and be able to see everything. Also, I tend to take that time to inspect items that I normally can't see anyway such as coolant lines and visually inspect for leaks.
back to your question, the reason your getting different answers is because some values are with the filter change, and some are not. I believe it is 3.2 if you change the filter as well. But any number that is given is just a guide. You should always check to make sure you have the proper amount of oil in. I would suggest putting in 3 quarts if your changing the filter as well, start the bike to let it circulate and then shut it off to check it. Add until you get the proper amount. You could also drain all of the oil from the bike and filter. Then as you empty a quart, fill it with the old oil. that way your putting in the same amount you have taken out. It will at least give you a safe level in which to check it. But 3 quarts should be really close to where you need to be.
Old Jun 20, 2011 | 10:52 PM
Poblete's Avatar
do you use a flash light to see the oil level? its hard to see because the peep hole is set so far in
Old Jun 21, 2011 | 01:35 AM
justasquid's Avatar
You could use a flashlight if your lighting is not good enough, but if you were outside in the sun, you should have no problem seeing the level. Just remember, you have to run the engine for a bit, then shut it off. Wait a minute and then check it. the oil will fill the glass up. I actually use a hand held extension mirror to check mine. I can sit on my bike and hold it level, then look down at the mirror and see where the level is at.
Old Jun 21, 2011 | 09:26 PM
Poblete's Avatar
thanks guys i changed it today put exactly 3.2 quarts.she seems to be a little high but nothing serious, she runs great and still pulls hard.
big24fanz
The Hurricane Saloon
25
Dec 9, 2011 08:52 AM
fra8877
May 7, 2009 10:48 AM
svx96
Oct 22, 2007 09:24 AM
Altiman94
Mar 1, 2006 12:46 AM
mini bagels
Sep 19, 2005 09:27 PM
